  2. Sigrity
  3. Join us for our next Live Experts Session: PowerSI & S-Parameter...
  • Replies 23
  • Subscribers 22
  • Views 2126
Join us for our next Live Experts Session: PowerSI & S-Parameter Analysis on July 29th 2026
Renu Vibha
Renu Vibha 2 months ago
Curious about S-Parameter extraction, Insertion Loss, and Return Loss?
Join us here for a live session with Cadence experts and get answers to your toughest Signal Integrity questions.
Wednesday July 29, 2026 at 8:30 PM – 9:30 PM IST
Topics:
S-Parameter Extraction
Insertion Loss Analysis
Return Loss Analysis
Why Join?
Ask questions live
Learn from real-world use cases
Gain practical SI insights
Connect with peers and industry experts
Don't miss this opportunity to engage directly with the experts and discover proven approaches to your SI challenges.
Bring your questions. Leave with answers.
  • ALLpdf
    ALLpdf 2 months ago in reply to CF202606104231 +3
    Please let me know if it answers your query... or if you have any more questions.
  • ALLpdf
    ALLpdf 2 months ago in reply to ALLpdf +3
    2‑port/3‑terminal device is not appropriate for AMM's 1‑port decap workflow. Its behavior is better represented by transfer terms (Z21/Z12) . Perform Z21/Z12 analysis in PowerSI, which is designed for…
  • ALLpdf
    ALLpdf 2 months ago in reply to CF202606104231 +2
    You can extract the S-Parameters, inductance, capacitance, and resistance of the power and ground nets of a package using the XtractIM " Electrical Performance Assessment " flow.
  • CF202606104231
    0 CF202606104231 2 months ago
    Many time we see Impedence plot of capacitor from S- Parameter in Sigrity tool does not  match data sheet, any reason?
  • ALLpdf
    0 ALLpdf 2 months ago in reply to CF202606104231
    Thank you for asking the question. Yes generally it happens when you check the S21/S12 s parameter plot of the capacitor in AMM of OPI tool.
  • ALLpdf
    AMM (OptimizePI) implements a 1‑port (two‑terminal) PDN decoupling workflow, where decoupling capacitors are modeled with power-ground terminals. By design, AMM plots Z11 (self‑impedance of the 1‑port device referenced to ground). Z12/Z21 (cross/transfer impedance terms for 2‑port networks) are not loadable or viewable in AMM.
    A decoupling capacitor used for PDN optimization is a two‑terminal component (power, ground). In this configuration, the device behaves as a 1‑port network.
    For a properly measured or modeled 1‑port decap, Z11 fully characterizes impedance vs. frequency, which is exactly what AMM needs for placement/sizing/optimization and target‑impedance checks
    • Vote Up +2 Vote Down
  • ALLpdf
    0 ALLpdf 2 months ago in reply to ALLpdf
    2‑port/3‑terminal device is not appropriate for AMM's 1‑port decap workflow. Its behavior is better represented by transfer terms (Z21/Z12). Perform Z21/Z12 analysis in PowerSI, which is designed for multi‑port network characterization and already aligns with Z21 per the datasheet.
    • Vote Up +3 Vote Down
  • ALLpdf
    Thanks for asking questions. Please go ahead with more questions.
