Community Feedback, Suggestions, and Questions Replicate ADE-XL Test Using SKILL/Ocean/OASIS
in the ADE-XL I right-click on a pre-defined test and select "Create Test Copy" to replicate the very same test content into a test named e.g. <lib>:<cell>:1:1, ...
Is there a way to do this using SKILL or Ocean or OASIS commands?
If there is no command, would you recommend a work-around for example by using axlPutTest()? Using this, I am getting an empty test which is not listed in my "test_states" folder at all.
Feedback is much appreciated!
Regards
CDNS Forum Thread CSS JS
CDNS - Fix Layout
