  2. Functional Verification Shared Code
  3. c interface with specman
  • Subscribers 38
  • Views 14627
archive over 18 years ago
 I need to call a  c function form specman . I had followed the below steps.
File vb_pattern.e
struct vb_pattern_s
  %data_in_ch0 : uint (bits : 4);   // data on channel 0
  %data_in_ch1 : uint (bits : 4);   // data on channed 1
  %data_in_ch2 : uint (bits : 4);   // data on channel 2
  %mode : uint (bits : 1);          // mode
  %enable : uint (bits : 1);        // enable
C export vb_pattern_s;
file  x_output_bfm.e
check_patterns()@clk_e is
 exp_viterbi_op();
routine exp_viterbi_op() is C routine viterbi_c_func;
---- EOF------
X.c
#include "vb_pattern.h"
void viterbi_c_func ()
 SN_TYPE(vb_pattern_s) vb_packet;
 SN_TYPE(mode)   mode;
 vb_packet = SN_SYS->ops
 mode = vb_packet->mode;
 printf("\n Printing from C environment MODE = %h \n", mode);
------------------- EOF----
x_top.e
import  tb/vb_pattern.e;
import  tb/x_input_bfm.e;
import  tb/x_output_bfm.e;
import  tb/x_cover_dut.e;
import  tb/x_env.e;
I  did the following comand
>> sn_compile.sh -h_only x_top.e -o vb_pattern.h
>> gcc -c viterbi.c -o viterbi.o
I am getting the following error
viterbi.c: In function `viterbi_c_func':
viterbi.c:6: error: `t__mode' undeclared (first use in this function)
viterbi.c:6: error: (Each undeclared identifier is reported only once
viterbi.c:6: error: for each function it appears in.)
viterbi.c:6: error: syntax error before "mode"
viterbi.c:7: error: `mode' undeclared (first use in this function)
Please help me resolve this.
Kesav
Originally posted in cdnusers.org by kesava
