  2. Functional Verification Shared Code
  3. Macro for multiple-value when definitions
  • Subscribers 38
  • Views 17049
archive over 18 years ago
The two macros below introduce new syntax for adding definitions to more than one 'when' determinant value at the same time. The first macro overloads 'extend' keyword and the second is the equivalent for 'when' keyword.
A use example:
extend [HUGE, BIG] packet {
    // definitions that pertain to these subtypes
The above code would be expanded in the following (naive) way:
extend HUGE packet {
extend BIG packet {
The macros code:
define 'statement>
       "extend \['name>,...\] 'name> ({;...})" as computed {
    for each in 'names> do {
        result = appendf("%sextend %s %s %s;",result,it,'name>,);
    result = appendf("{%s}",result); // required only for versions 6.1.1 or earlier
define 'struct_member>
       "when \['name>,...\] 'name> ({;...})" as computed {
        result = appendf("%swhen %s %s %s;",result,it,'name>,);
Originally posted in cdnusers.org by matanvax
    Hm, are you sure it compiles ? I get various errors, e.g. the syntactic category is missing (at least in my browser the space after "define" is empty)...
    Cheers,
    Thorsten.
    Originally posted in cdnusers.org by blutsvente
    archive over 17 years ago
    Hi Thorsten,
    the web browser does not display the
    BR
    Ernst
    define 'statement> "extend \['exp>,...\] 'name> ({;...})" as computed {for each in 'exps> do { result = appendf("%sextend %s %s %s;",result,it,'name>,);}; result = appendf("{%s}",result); };
    define 'struct_member> "when \['exp>,...\] 'name> ({;...})" as computed {for each in 'exps> do {result = appendf("%swhen %s %s %s;",result,it,'name>,); }; result = appendf("{%s}",result); };
    Originally posted in cdnusers.org by zwinge
