  2. Functional Verification Shared Code
  3. Specman Makefile generator utility
  • Subscribers 39
  • Views 20489
StephenH
StephenH over 17 years ago
I've heard lots of people asking for a way to generate Makefiles for Specman code, and it seems there are some who don't use "irun" which takes care of this automatically. So I wrote this little utility to build a basic Makefile based on the compiled and loaded e code.
It's really easy to use: at any time load the snmakedeps.e into Specman, and use "write makefile <name> [-ignore_test]".
This will dump a Makefile with a set of variables corresponding to the loaded packages, and targets to build any compiled modules.
Using -ignore_test will avoid having the test file in the Makefile, in case you switch tests often (who doesn't?).
It also writes a stub target so you can do "make stub_ncvlog" or "make stub vhdl" etc.
The targets are pretty basic, I thought it was more useful to #include this into the main Makefile and define your own more complex targets / dependencies as required.
The package uses the "reflection" facility of the e language, which is now documented since Specman 8.1, so you can extend this utility if you want (please share any enhancements you make).
 Enjoy! :-)
Steve.
snmakedeps_v1.0.zip
  • StephenH
    I've updated this utility a bit, to make the targets more useful. Now, even if you only loaded the file into Specman or Specview, the Makefile will have a target for compiling this with sn_compile.sh. Here's an example:
    First, I load a couple of files into Specman:
    specman -c "load snmakedeps ; load vr_ad/e/vr_ad_top ; load vr_xbus/examples/vr_xbus_config.e ; write makefile Makefile.sn -ignore_test"
    Now I use the generated Makefile.sn to incrementally compile my vr_ad_top and vr_xbus_config modules:
    compile make -f Makefile.sn sncompile
    This results in the executables and shared libraries that I can use with specrun/specview or ncsim.
    make -f Makefile.sn stub_ncvhdl stub_ncvlog
    This results in my stubs files being generated. If I already ran the "make sncompile",  the stubs are generated using the compiled code, otherwise they're written using the loaded e code.
    Here's an example of the Makefile.sn that's generated:
    ## Auto-generated Makefile for Specman - DO NOT EDIT
    ## compiled module vr_ad_top
    vr_ad_top_files=\
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_types.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_sets_interface.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_sets_internal_proto.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set32_mem.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set32_nodes.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set32_lowlevel.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set32_hilevel.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set32_rnd.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set_inf_mem.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set_inf_nodes.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set_inf_lowlevel.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set_inf_hilevel.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_set_inf_rnd.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_sets/e/vr_sets_top.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_api.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_sequence_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_sets.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_imp.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_reg_imp.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_map_imp.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_sequence.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_vt_page_slice_patch.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_vt.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_predefined_seq.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_macro.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_mem_api.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_mem_imp.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_mem_obj.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_mem_vt.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_top.e
    ## compiled module vr_xbus_config
    vr_xbus_config_files=\
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/shr_ram/e/shr_ram_main.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/shr_ram/e/shr_ram_top.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_config_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_types_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_trans_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_signal_map_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_bus_monitor_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_agent_monitor_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_agent_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_env_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_arbiter_sequence_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_master_sequence_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_slave_sequence_h.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_bus_monitor.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_agent_monitor.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_bfm.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_arbiter_bfm.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_master_bfm.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_slave_bfm.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_agent.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_env.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_protocol_checker.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_coverage.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_end_test.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_top.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/e/vr_xbus_port_config.e \
    /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/examples/vr_xbus_config.e
    libsn_vr_ad_top.so: $(vr_ad_top_files)
    sn_compile.sh -exe -shlib -enable_DAC /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/util_lib/vr_ad/e/vr_ad_top.e
    libsn_vr_xbus_config.so: $(vr_xbus_config_files) libsn_vr_ad_top.so
    sn_compile.sh -exe -shlib -enable_DAC /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/examples/vr_xbus_config.e
    sncompile: libsn_vr_xbus_config.so
    echo 'Recompiling e code...'
    # Use 'make stub_<sn_adapter_name>' to build the desired stubs file,
    # for example: 'make stub_ncvhdl'.
    stub_%: $(vr_ad_top_files) $(vr_xbus_config_files)
    if [ -x ./vr_xbus_config ]; then\
    ./vr_xbus_config -c 'write stubs -$*'; \
    else\
    specman -c 'load /export/home/stephenh/Tools/IPCM08.10.004-s/ipcm/ovm_lib/erm_ex_lib/vr_xbus/examples/vr_xbus_config.e ; write stubs -$*';\
    fi
    snmakedeps_v1.2.zip
  • StephenH
    At risk of producing a monologue that nobody is reading... ;-)
    A colleague asked if I could update the generator to produce a "tarball" target, to make it easy to archive or transfer the source code.
    So here it is! The Specman command is unchanged, you simply have a new make target called tarball:
    make -f Makefile.sn tarball
    snmakedeps_v1.3.zip
  • rheychrox06
    rheychrox06 over 16 years ago
     Oh,..this seems to be quite complicated..
  • StephenH
    StephenH over 16 years ago
    Aww... It wasn't supposed to be complex.
    Drop me an email if you'd like some help using it, maybe my forum post didn't make it very clear which bits are generated and which you have to do. Normally it should be only 1 command.
