  3. Skill command to create custom color definition for Vir...
  • Replies 10
  • Views 17946
Skill command to create custom color definition for Virtuoso
TeeBro
TeeBro over 13 years ago
I have an application that will highlight a net within a layout much like the Assura probing app.  The problem is the highlight is not very viewable.  I have written code to change the Cadence hiLite colors to be more viewable ( ie thickLine, stipple, etc ) but what I really want is for the color to "blink".  I need to create a custom color definition that blinks.  I can create the color using drMakeColor but there is not an option to make it blink.  So far the only way I have been able to create the blink colors is to define them in a drf file and read it in with drLoadDrf.  Example:  drDefineColor( (display    blinkRed   255   0   0   t ) ).
Is there any way to create this color without loading a drf file?
  • skillUser
    skillUser over 13 years ago
    I've written some code in the past that dynamically changes a packet on the fly by using drSetPacket to change which packet a layer-purpose is assigned to, so you might be able to do something similar? If I can work out how I will attach the code here... If not, look for CCStoggleMarkerWarning, or click on this link CCStoggleMarkerWarning.il
    Best regards,
    Lawrence.
  • skillUser
    Best regards,
    Lawrence.
