  3. How to export GDS using terminal
  • Views 20585
Muralidhar
Muralidhar over 8 years ago
I want to export GDS from the given layout. I know that it can be done by using Virtuoso CIW like File-->Export-->streamOut and giving the required fields. But I want to do it using terminal (linux commands). I have seen that it can be done using strmout command but I don't know how to do it. Please tell me how to use it. If possible give an example.
  • Muralidhar
    Actually my goal is to generate busplots using perl script in the terminal. I wrote some script that will generate busplot for a particular net using the command
    "calibre -drc filename " in the terminal where we source the virtuoso to get licenses. But the problem with this is we need to enter gds name and netname manually.
    I have create a perl script that will generate a dummy file with the gdsname and netname like as below in the terminal
    "perl filename gdsname netname". It is creating a file with the modifications like gds and net names. But my question is how to include this strmin (or) strmout functions in the perl script? Is it possible or not ?
  • Muralidhar
