  3. [Solved] Trying to wrap a script in unwindProtect, progn...
  • Replies 7
  • Views 13822
[Solved] Trying to wrap a script in unwindProtect, progn complains: too many arguments
jriad
jriad over 4 years ago
My use case is that I'm trying to invoke some SKILL code from within Python. To that end, I'm spawning a "virtuoso -nograph" process and passing my skill code to its standard input.
To make sure the virtuoso process will exit no matter what (so that my Python script can continue), this is the SKILL code I'm sending it:
    (unwindProtect
      (progn
        ;; My code goes here
    (exit))
The problem is, my code can be quite long so I sometimes get an error like:
      *Error* progn: too many arguments (at most 65535 expected, 174884 given)
How can I approach this so that my SKILL code always exits and doesn't hang around waiting for more input and hijacking control from my Python script?
I have also tried writing my code out to a file and tacking an (exit) at the end of it then invoking the process as "virtuoso -nograph -restore mycode.il", but the problem is, if there are any errors in the code, the (exit) call will never be reached and the REPL will keep waiting for input and not return control to the Python script.
Am I going about this all wrong? Is there a better approach to this?
  • jriad
    Update: I tried splitting the code into many (unwindProtect ...) forms to make sure the number of arguments to (progn...) never exceeded the limit but I still got a "literal stack overflow" error because the code size was too large.
    The approach I ended up taking was different: I made my Python script write out all the annotation info to a text file and then I wrote a SKILL function that reads the text file line by line and creates annotations in the layout based on the info it reads from each line. I was then able to wrap this function call in an (unwindProtect...) from within Python with no issues. Not only did this work without overflow errors, it was blazing fast: it created ~44k annotations in under 2 minutes.
  • jriad
