  2. Functional Verification Shared Code
  3. Posting code to the forum
  • Subscribers 38
  • Views 15188
archive over 18 years ago
When posting code to the forums, copy from a text editor such as notepad, not from word or Outlook. Be sure to click the HTML tab BEFORE you paste your text.
Click on the "html" mode tab on your "reply" dialog box. Then wrap your text with like this:
pasted text
NOTE: Do not put a space in the I have done that here so it will show up as text. Also, be sure to click the HTML tab BEFORE you paste your text. This is how it will look when coded correctly pasted text
Originally posted in cdnusers.org by Administrator
    Hi
    I would like to know on a done design if theres a change of one macro , how do i incorporate these changes to the design using SOC Encounter 6.2. Is it that I load the old config file with the new library of the macro and then load the def of theoriginal routed clean design.
    Inputs on this would be very much helpful
    Thanks in advance
    Originally posted in cdnusers.org by jmayee
