  3. How can we minimise the errors created while autorouting...
  • Views 13380
How can we minimise the errors created while autorouting the board in the specctra autorouter?
Neha Anu
Neha Anu over 16 years ago
Hi all,
I've autorouted the .brd file by Route ->Route Editor command in the Allegrto PCB Design GXL.I heard that the constraints set on the Allegro PCB Design GXL is transported to Specctra while giving the above command for autorouting.I've set the constraints such as line to line spacing,pad to line spacing etc,still these errors are generated after the .brd file is routed in the specctra.how can we minimize these errors?Is there any settings for this?
Can anyone pls xplain this?
Thanx
Neha
  • Neha Anu
    Hi oldmouldy,
    The use of Edit>Delete Wires>Conflicts can be done after the autorouting,right?This will take alot of manual work to re-route the wires.Is there any measure to reduce the errors while routing?
    Is there any settings in the Route Editor or any commands in the .do file using that should obey the constraints inherited from the Allegro PCB Designer GXL and the constraints set on the .do file??
    Neha
  • Neha Anu
    Hi oldmouldy,
    Neha
