  2. Functional Verification Shared Code
  3. Specman Makefile generator utility
  • Subscribers 39
  • Views 19245
StephenH
StephenH over 17 years ago
I've heard lots of people asking for a way to generate Makefiles for Specman code, and it seems there are some who don't use "irun" which takes care of this automatically. So I wrote this little utility to build a basic Makefile based on the compiled and loaded e code.
It's really easy to use: at any time load the snmakedeps.e into Specman, and use "write makefile <name> [-ignore_test]".
This will dump a Makefile with a set of variables corresponding to the loaded packages, and targets to build any compiled modules.
Using -ignore_test will avoid having the test file in the Makefile, in case you switch tests often (who doesn't?).
It also writes a stub target so you can do "make stub_ncvlog" or "make stub vhdl" etc.
The targets are pretty basic, I thought it was more useful to #include this into the main Makefile and define your own more complex targets / dependencies as required.
The package uses the "reflection" facility of the e language, which is now documented since Specman 8.1, so you can extend this utility if you want (please share any enhancements you make).
 Enjoy! :-)
Steve.
snmakedeps_v1.0.zip
  • rheychrox06
    rheychrox06 over 15 years ago
     Oh,..this seems to be quite complicated..
  • rheychrox06
