  2. Functional Verification Shared Code
  3. Specman Mode for Emacs
  • Replies 7
  • Subscribers 41
  • Views 29363
hannes
hannes over 11 years ago
Attached is the latest emacs mode for e/Specman - version 1.23
Please follow the install instructions in the top section of the actual file
(after unzipping it) to install/load this package with your emacs.
specman-mode_1.23.zip
  • guzman
    guzman over 11 years ago
    thanks abogados madrid
  • Martin Garcia
    Martin Garcia over 11 years ago
    This is also very useful for me, I was looking for.
  • Martin Garcia
     Penalista
  • krawi992
    krawi992 over 10 years ago
    Thanks!
  • thanik60
    thanik60 over 7 years ago
    ขอบคุณมากครับสำหรับความรู้ เป็นประโยชน์ มากๆ เลย  ufabet http://www.ufa007.com/ufabet:AO
  • muzicarski
    muzicarski over 7 years ago
    Thank You very much for this!
    I found this through Your post on a blog, titled "e Language Editing with Emacs". May I suggest that You provide a link to a web page with instructions on how to manually install packages in Your original post? I had trouble with this issue, and I believe that more people will, so a simple guideline like a link could be very helpful! i.e. Like this one: http://ergoemacs.org/emacs/emacs_installing_packages.html  .
    Once again, thank You very much, You saved my day!
  • hannes
    hannes over 7 years ago in reply to muzicarski
    once you unpack the tar file, have a look at the header area. There is an install section, which explains how to load this package.
