  2. Hardware/Software Co-Development, Verification…
  3. NClaunch : ncelab: *E,CUVHNF error
  • Subscribers 50
  • Views 19498
Anklon
Anklon over 8 years ago
I'm trying to simulate a practice code . Verilog verification of my code do not give any error.But when I try to elaborate, this error is being showed:
ncelab: *E,CUVHNF (./FSM_test.v,17|20): Hierarchical name component lookup failed at 'l'
What does this mean? How can I debug this error ? Is there any archive or list of possible error list so that I don't have to ask in forum to understand the errors.
  • TAM1
    TAM1 over 8 years ago
    This error is saying that you have used a hierarchical name in your Verilog source code. But the elaborator can't find the signal or module 'I' that you have included in that hierarchical name.
    To learn more about what errors mean, use the "nchelp" utility. It takes as arguments the tool issuing the error message and the error message code itself.
    > nchelp ncelab CUVHNF
  • Rspatel
    Rspatel over 4 years ago in reply to TAM1
    Thank you very much TAM1. One more doubt is xmelab i am using that will give answer for the same *E,CUVHNF ?
