  2. Hardware/Software Co-Development, Verification…
  3. Replace Cache useing TCL command
  • Subscribers 49
  • Views 16703
Ea222
Ea222 over 7 years ago
I'm using OrCad 17.2 and in the company I'm wokring at there was a change in the database folder (from driver F to G for example) and it effects the option of synchronise using the Part Manager. and changing manually each part in the Desgin Cahce can be a pain.
Is there any way I can make a TCL script that will run and replace a part cahce with other? Better if I can call from a table to read, and write from other collum.
I would really be happy for an example.
Thanks for the help.
