  2. Functional Verification Shared Code
  3. Creating cover items for sparse values/queue or define in...
  • Subscribers 40
  • Views 9320
Creating cover items for sparse values/queue or define in specman
rgarcia071
rgarcia071 over 6 years ago
I have a question I want to create a cover that consists a sparse values, pre-computed (a list or define) for example l = {1; 4; 7; 9; 2048; 700} I'd like to cover that data a (uint(bits:16)) had those values, Any suggestion on how to achieve this, I'd prefer to stay away from macros, and avoid to write a lot of code
struct inst {
  data :uint(bits:16);
  opcode :uint(bits:16);
  !valid_data : list of uint(bits:16) = {0; 12; 10; 700; 890; 293;};
  event data_e;
  event opcode_e;
  cover data_e is {
     item data using radix = HEX, ranges = {
     //I dont want to write all of this
     range([0], "My range1");
     range([10], "My range2");
     //... many values in between
    range([700], "My rangen");
    item opcode;
   cross data, opcode;
post_generate() is also {
    emit data_e;
  • Tudor Timi
    Tudor Timi over 6 years ago
    The ranges you pass to the ranges option have to by listed manually. There's no way of passing a list of range or something like that. Also note that the values used in the range have to either be literals or global scope variables that are set by the end of the setup phase.
    The only way I can see at the moment is to use a define as computed macro.
  • rgarcia071
    rgarcia071 over 6 years ago in reply to Tudor Timi
    Thank you very much Tudor, i was expecting specman to have something similar to 1800-2012 SV to define buckets using a list, I'll give it a try to the computed macro
