  3. Text variables
  • Views 19346
Text variables
GForte
GForte over 4 years ago
Hello, I was wondering how can I create variable fields in the layout.
To start, I have a template for some type of designs, and I would like that one of the texts on the silkscreen changes accordingly to an external variable, like the folder name, or a text file in the same folder.
I was thinking something similar to a page frame that changes the date automatically. How can I generate that type of fields?
  • RFinley
    RFinley over 4 years ago
    In Support.Cadence.Com, there is a skill utility that appears to be a good starting point.
    "SKILL code to add a few useful text variables like date/time, and last modified date/time to the board file"
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009Mq2DUAS&pageName=ArticleContent
    This utility will add the text for the following:
    • Number of pads in the design
    • Filename and location
    • Date and time
    • Last modified date and time
    • Scale factor for print
    Using this SKILL utility, once the text variables are placed in the board file, the subsequent add_text run would automatically update the variable values if they have changed.
  • GForte
    GForte over 4 years ago in reply to RFinley
    Many thanks RFinley, I was looking something more automated like the date fields on Schematic Capture frame object, that refreshes everytime you open it or save the file.
  • RFinley
    RFinley over 4 years ago in reply to GForte
    I don't know how long it will take for Cadence to implement this through a feature request.
    Need to find a SKILL event trigger for saving the board file.
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    try
    axlTriggerSet('save 'add_text)
  • excellon1
    excellon1 over 4 years ago in reply to RFinley
    That's a very handy utility & a time saver.
    Thanks for the info RF.
