  3. 17.4 Design Sync Fails without providing errors
  • Replies 8
  • Views 22552
DDPCB
DDPCB over 4 years ago
As the title suggests I am unable to perform design sync between OrCAD Capture and Allegro. When I add a layout and try to sync to it I am given ERROR(ORCAP-2426): Cannot run Design Sync because of errors. See session log for error details.
Session Log
[ORPCBFLOW] : Invoking ECO dialog.
INFO(ORNET-1176): Netlisting the design
INFO(ORNET-1178): Design Name:
C:\USERS\DDOYLE\DOCUMENTS\CADENCE\BOARDS\REMOTE POWER DEVICE\CAPTURE\REMOTE_POWER_DEVICE.DSN
Netlist Directory:
c:\users\ddoyle\documents\cadence\boards\remote power device\layout\allegro
Configuration File:
C:\Cadence\SPB_17.4\tools/capture/allegro.cfg
pstswp.exe - pst - d "C:\USERS\DDOYLE\DOCUMENTS\CADENCE\BOARDS\REMOTE POWER DEVICE\CAPTURE\REMOTE_POWER_DEVICE.DSN"- n "c:\users\ddoyle\documents\cadence\boards\remote power device\layout\allegro" - c "C:\Cadence\SPB_17.4\tools/capture/allegro.cfg" - v 3 - l 31 - s "" - j "PCB Footprint" - hpath "HPathForCollision"
Spawning... pstswp.exe - pst - d "C:\USERS\DDOYLE\DOCUMENTS\CADENCE\BOARDS\REMOTE POWER DEVICE\CAPTURE\REMOTE_POWER_DEVICE.DSN"- n "c:\users\ddoyle\documents\cadence\boards\remote power device\layout\allegro" - c "C:\Cadence\SPB_17.4\tools/capture/allegro.cfg" - v 3 - l 31 - s "" - j "PCB Footprint" - hpath "HPathForCollision"
{ Using PSTWRITER 17.4.0 d001Dec-14-2021 at 09:00:49 }
INFO(ORCAP-36080): Scanning netlist files ...
Loading... c:\users\ddoyle\documents\cadence\boards\remote power device\layout\allegro\pstchip.dat
Loading... c:\users\ddoyle\documents\cadence\boards\remote power device\layout\allegro\pstxprt.dat
Loading... c:\users\ddoyle\documents\cadence\boards\remote power device\layout\allegro\pstxnet.dat
packaging the design view...
Exiting... pstswp.exe - pst - d "C:\USERS\DDOYLE\DOCUMENTS\CADENCE\BOARDS\REMOTE POWER DEVICE\CAPTURE\REMOTE_POWER_DEVICE.DSN"- n "c:\users\ddoyle\documents\cadence\boards\remote power device\layout\allegro" - c "C:\Cadence\SPB_17.4\tools/capture/allegro.cfg" - v 3 - l 31 - s "" - j "PCB Footprint" - hpath "HPathForCollision"
INFO(ORNET-1179): *** Done ***
This issue started to occur after I changed parts that exist on previously created PCBs. I changed the following leading up to this:
1. Added height in Allegro to many of my components using the Setup->Area->Package Height tool.
2. Changed the reference designator category in OrCAD Capture to TP for several components on board.
Any advice here would be most welcome. Thanks!
  • steve
    steve over 4 years ago
    The netlist was generated successfully (you can see the three files created). Have a look in the netrev.lst file which will be in the same directory as the board file. This should give you an idea.
  • DDPCB
    DDPCB over 4 years ago in reply to steve
    Hi Steve! The netrev.lst file I found in this folder is from the original design sync performed last year and indicates no errors. If I remove this netrev.lst file from the directory and then attempt to design sync again another instance of the file is not generated and I am issued the same error. Is there something specific I should lookout for in the netrev.lst I have besides the error list or is there another path I should investigate? I notice that the design sync is failing on multiple boards as well, not just this one.
  • steve
    steve over 4 years ago in reply to DDPCB
    OK try opening the board in PCB Editor and Import the netlist the manual way and see if that produces a netrev.lst / detail of errors.
  • DDPCB
    I generated the netlist in OrCAD Capture, and successfully imported it into Allegro. The netrev.lst generated in this way indicates no errors, oversights, or warnings detected but when I save the board file, close Allegro and return to OrCAD Capture to design sync I am issued the same error.
  • steve
    OK try opening the schematic in OrCAD Capture then try PCB - New Layout, for Import Board File and Board use the board file you have and then see if that works. If it does now make a change and see if you can run Design Sync. Also make sure you are up to date in regard to hotfixes (currently 17.4-2019 S024).
