  3. CIS Standard BOM to Excel 365
  • Subscribers 166
  • Views 18046
NePePCB
NePePCB over 4 years ago
I'm not able to export a CIS Standard BOM to a Microsoft 365 Excel (business subscription, version 2111).
Selecting the "Export BOM report to Excel" option opens a new Excel window, but OrCAD (17.4-2019 S023) won't fill it with any data...
I tried it on a different PC with Microsoft Office Professional Plus 2019 Excel (strangely the version number is the same: 2111) and with OrCAD 17.4-2019 S016 and it worked flawlessly.
Does anybody experiencing the same issue?
Does the Excel variant, the OrCAD version or the PC itself causing this?
Thanks for any help!
  • steve
    steve over 4 years ago
    There appears to be an issue with S023 and S024. This has been reported to Cadence and is currently under investigation. For now use the S016 until this issue is fixed or don't export the BOM to Excel which creates a TAB delimited text file that can then be opened in Excel.
  • NePePCB
    NePePCB over 4 years ago in reply to steve
    Thanks for the quick reply and the advice!
  • Zhifeng Jin
    Zhifeng Jin over 4 years ago in reply to steve
    Hi Steve!Has the problem of S025 been solved? This problem bothers me, do not want to version backJoy
  • Zhifeng Jin
    However, it has not been solved!
    Orcad Capture 17.4 hotfix025 has just been installed. Exporting from CIS standard BOM to excel will still be a blank sheet.
