  3. Migrating from files Orcad Layout 16.2
  • Views 13440
RobHickman
RobHickman over 4 years ago
I have managed to convert our old schematic and PCD file to from Layout 16.2 to 17.4
I have exported the footprints and moved them to the correct lib directory.
I get no DRC errors and I can build a new netlist file. The problem is I can't get the PCB editor to update using the new netlist and get the following error:
I cannot figure out how to fix the Name is too long error.
(    Allegro Netrev Import Logic                                      )
(    Drawing          : 70055R2.brd                                   )
(    Software Version : 17.4S023                                      )
(    Date/Time        : Tue Dec 14 18:54:25 2021                      )
------ Directives ------------
Ripup etch:                  Yes
Ripup delete first segment:  No
Ripup retain bondwire:       No
Ripup symbols:               IfSame
Missing symbol has error:    No
DRC update:                  Yes
Schematic directory:         'C:/AFS/70055 PCB Test 2'
Design Directory:            'C:/AFS/70055 PCB Test 2'
Old design name:             'C:/AFS/70055 PCB Test 2/70055R2.brd'
New design name:             'C:/AFS/70055 PCB Test 2/70055R2.brd'
CmdLine: netrev -$ -i C:/AFS/70055 PCB Test 2 -x -u -t -y 2 -h -z -q netrev_constraint_report.xml C:/AFS/70055 PCB Test 2/#Taaaaae57776.tmp
------ Preparing to read pst files ------
Starting to read C:/AFS/70055 PCB Test 2/pstchip.dat
   Finished reading C:/AFS/70055 PCB Test 2/pstchip.dat (00:00:00.02)
Starting to read C:/AFS/70055 PCB Test 2/pstxprt.dat
   Finished reading C:/AFS/70055 PCB Test 2/pstxprt.dat (00:00:00.00)
Starting to read C:/AFS/70055 PCB Test 2/pstxnet.dat
   Finished reading C:/AFS/70055 PCB Test 2/pstxnet.dat (00:00:00.00)
------ Oversights/Warnings/Errors ------
#1   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'SW DPDT_9_SWITCH_OTTO_ALT_SW DPDT': 'Name is too long.'.
ERROR(SPMHNI-170): Device 'SW DPDT_9_SWITCH_OTTO_ALT_SW DP' has library errors. Unable to transfer to Allegro.
#2   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'SW DPDT_10_SWITCH_OTTO_LIGHTS_SW DPDT': 'Name is too long.'.
ERROR(SPMHNI-170): Device 'SW DPDT_10_SWITCH_OTTO_LIGHTS_S' has library errors. Unable to transfer to Allegro.
#3   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'SW DPDT_7_SWITCH_OTTO_ALT_SW DPDT': 'Name is too long.'.
ERROR(SPMHNI-170): Device 'SW DPDT_7_SWITCH_OTTO_ALT_SW DP' has library errors. Unable to transfer to Allegro.
#4   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'SW DPDT_3_SWITCH_OTTO_MASTER_SW DPDT': 'Name is too long.'.
ERROR(SPMHNI-170): Device 'SW DPDT_3_SWITCH_OTTO_MASTER_SW' has library errors. Unable to transfer to Allegro.
#5   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'SW DPDT_6_SWITCH_OTTO_LIGHTS_SW DPDT': 'Name is too long.'.
ERROR(SPMHNI-170): Device 'SW DPDT_6_SWITCH_OTTO_LIGHTS_SW' has library errors. Unable to transfer to Allegro.
#6   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'SW DPDT_3_SWITCH_OTTO_MASTER_DPDT': 'Name is too long.'.
ERROR(SPMHNI-170): Device 'SW DPDT_3_SWITCH_OTTO_MASTER_DP' has library errors. Unable to transfer to Allegro.
#7   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'CONNECTOR DB15_DSUBVPTM15_CONNECTOR DB15': 'Name is too long.'.
ERROR(SPMHNI-170): Device 'CONNECTOR DB15_DSUBVPTM15_CONNE' has library errors. Unable to transfer to Allegro.
#8   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'CONNECTOR DB9_DSUBVPTM9_CONNECTOR DB9': 'Name is too long.'.
ERROR(SPMHNI-170): Device 'CONNECTOR DB9_DSUBVPTM9_CONNECT' has library errors. Unable to transfer to Allegro.
#9   ERROR(SPMHNI-175): Netrev error detected.
ERROR(SPMHDB-195): Error processing 'M6': Text line is outside of the extents..
------ Library Paths ------
MODULEPATH =  .
           C:/Cadence/SPB_17.4/share/local/pcb/modules
PSMPATH =  .
           symbols
           ../symbols
           C:/Cadence/SPB_17.4/share/local/pcb/symbols
           C:/Cadence/SPB_17.4/share/pcb/pcb_lib/symbols
           C:/Cadence/SPB_17.4/share/pcb/allegrolib/symbols
PADPATH =  .
           symbols
           ../symbols
           C:/Cadence/SPB_17.4/share/local/pcb/padstacks
------ Summary Statistics ------
#10  Run stopped because errors were detected
netrev run on Dec 14 18:54:25 2021
   DESIGN NAME : '70055R2'
   PACKAGING ON Nov  2 2021 14:32:04
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
 10 errors detected
 No oversight detected
 No warning detected
cpu time      0:00:27
elapsed time  0:00:00
  • steve
    steve over 4 years ago
    Open the filename.brd and go to Setup - Design Parameters - Design tab and set the long name size to 255. This pdf may also help with other issues Microsoft Word - Translating an Existing OrCAD Layout Design to PCB Editor.docx
