  3. Allegro 17.4 always reports new files as created in 17....
  • Replies 7
  • Views 22262
Allegro 17.4 always reports new files as created in 17.2
Jason T
Jason T over 4 years ago
Hello. I am using Cadence 17.4 tools. When I open a package symbol (.dra) or board file (.brd) in Allegro that was created in an older version of the tool I get a message like this one (as expected):
"The design created using release 17.2 will be updated for compatibility with the current software..."
If I create a symbol or board file from scratch in the 17.4 tool then open it later, I get the same message. (always referring to version 17.2 which is the previous version I was using here).
So far this has not caused me any problems, but I would like to understand why it is doing this in case I have something setup incorrectly.
I only have version 17.4 installed. I am not exporting to a downrev version when I save (i.e. not using File->Export->Downrev design…) and in User Preferences->Drawing I don’t have anything selected for database_compatibility_mode. What else might I check?
FYI here is the tool version information that I see after selecting Help->About Symbol:
OrCAD PCB Designer Standard 17.4-2019 S012 [10/26/2020] Windows SPB 64-bit Edition
Thanks -Jason
  • RFinley
    RFinley over 4 years ago
    In User Preferences, search for the variable "databse_compatibility_mode".  I think its in "unsupported" folder.
    It looks like you have it set to only export 17.2 from 17.4.
  • Jason T
    Jason T over 4 years ago in reply to RFinley
    Thanks for the reply. If I go to Setup->User Preferences and select the Drawing folder there is a database_compatibility_mode field. It is blank, but if I click on the pull-down arrow it shows a 17.2 option. Since the field is normally blank I assume that I am not selecting that option. If I select the List All button there is no entry for database_compatibility_mode. I don't see anything that looks relevant under the Unsupported folder.
  • RFinley
    RFinley over 4 years ago in reply to Jason T
    The first time I tried it, I cleared the 17.2 option but didn't click "apply"
    Worst case, check your pcbenv/env file.   Look for a line in the bottom section that says:
    "set database_compatibility_mode = 17.2"
    remove it.  Save your env file.  Restart Allegro.
    Allegro will startup with a new board and warn you that it will be saved in 17.2 if this variable is still set.
  • sfrederick
    sfrederick over 4 years ago
    See the following article on Cadence Online Support:
    A .dra file saved using 17.4 release gives a message that it is created using 17.2 release when opened in 17.4
  • Jason T
    Hmm, I see no such setting in the env file (C:\Cadence\SPB_17.4\share\pcb\text\env).
