  2. Allegro X APD
  3. Aligning Components using Offset Mode in Allegro X APD
  • Subscribers 67
  • Views 6354
PCBTech
PCBTech over 2 years ago
Starting SPB 23.1, in Allegro X PCB Editor and Allegro X Advanced Package Designer, you can align components by using offset mode. Earlier only spacing mode was available.
Follow these steps to Align Components using Offset Mode:
  1. Set Application Mode to Placement Edit.
  2. Drag the components that need to be aligned and right-click and choose Align Components.
  3. Now, in the Options tab, you will notice Spacing Section with Equal Offset. You can equally and individually offset the components by using the +/- buttons for increment or decrement.
