  2. Allegro X APD
  3. How to reuse device files for existing components
  • Subscribers 66
  • Views 6315
PCBTech
PCBTech over 2 years ago
Have you ever encountered ERROR(SPMHNI-67) while importing logic? If yes, you might already know that you had to export libraries of the design and make sure that paths (devpath, padpath, and psmpath) include the location of exported files.
Starting in SPB23.1, if you go to File > Import > Logic/Netlist and click on the Other tab, you will see an option, Reuse device files for existing components.
After selecting this option, ERROR(SPMHNI-67) will no longer be there in the log file, because the tool will automatically extract device files and seamlessly use them for newly imported data. In other words, SPB_23.1 lets you reuse the device / component definitions already in the design without first having to dump libraries manually. An excellent improvement, don’t you think?
