  2. Allegro X APD
  3. How to add wirebond profile to a die pin?
  • Subscribers 67
  • Views 5850
PCBTech
PCBTech over 2 years ago
Starting SPB 23.1, a new pin property, WIREBOND_PROFILE_NAME is introduced. This property can be used to define a wirebond profile to a die pin. When adding a wirebond, the pin will use the profile defined in the WIREBOND_PROFILE_NAME property associated to the die pin.
Assign the WIREBOND_PROFILE_NAME property to the die pin using Edit > Properties and set the desired wirebond profile name in the Value field.
The following image displays the WIREBOND_PROFILE_NAME property assigned to the pin and wire profile of the Wire Bond for that pin.
