  2. Allegro X APD
  3. How to export and import symbols and component properties...
  • Subscribers 66
  • Views 2705
How to export and import symbols and component properties through Die Text wizards
PCBTech
PCBTech over 2 years ago
Starting SPB 23.1, Allegro X APD lets you import/export the symbol and component properties by using Die Text-In/Out wizards.
Exporting the symbol
You can export the symbol by using File > Export > Die Text-Out Wizard.
In the Die Text-Out Wizard window, you can see the newly added options, that is, Component Properties and Symbol Properties.
This entire information including the properties will be saved in a text file.
Importing the symbol
You can import the same text file in Allegro X APD by using Die Text-In Wizard.
Choose the text file you want to import.
Symbol properties added in the text file will be visible in the Die Text-In Wizard window.
