  2. Allegro X APD
  3. Skill to delete selected net and padstakck via
  • State Verified Answer
  • Subscribers 67
  • Views 6676
zpofrp
zpofrp over 1 year ago
I want to delete via use skill,but i dont write this skill. can you help me.
This skill has Interactive interface,the interface can imput  Select Net and select padstack;
I can  use temp group to select the via;
example,i want to delete via,the padstack is L1:L3,the net is vss. i can imput padstack  L1:L3 and select net: VSS;
Note: The green is VSS,the padstack L1:L3 and L3:L5 ;
thanks
  • Tyler
    +1 Tyler over 1 year ago
    I don't think you actually need to write any SKILL for this. This is what the Find by Query feature is for. See picture shown below. The find by query tool allows you to create search / filter criterias. Then, you can use this (either with the table show at the bottom right or by enabling the "by saved query" option in the main find panel) to drive the interactive delete command.
    The nice thing here, versus the SKILL solution, is you can rapidly add more filters, you can do things like "any of these 5 nets" or "vias that start at layer 1 and end at layer 3", without having to write a single line of code. Once you've saved your queries, they can be accessible in any design you're working on.
    Cheers,
    - Tyler
  • zpofrp
    0 zpofrp over 1 year ago in reply to Tyler
    thanks so much,
    i dont konw this fuction.
