  2. Allegro X APD
  3. Allegro: Tip of the Week : Push Connectivity
  • Subscribers 67
  • Views 6247
TCHA
TCHA over 1 year ago
At times, there might arise a condition in the design where you need to push the net of selected pins to all its physically connected objects. For example, a few pins are updated with a new net, and it is required to push the new net to all its connected objects. At times, you might update the die or copy routing to other components, when a portion of routing gets the wrong net.
To propagate the net of the pin to all its physically connected objects, Allegro X APD uses the standalone command, Push Connectivity.
You can call the command through Logic > Push Connectivity.
Alternately, you can use the push connectivity command at the command line. Once the command is active, it lets you select pins or symbols that will be used to push net connectivity to all connected objects.
Presently, dynamic shapes and filled rectangles are not considered as part of connectivity. Static shapes are supported.
  • zpofrp
    zpofrp over 1 year ago
    it is very good for package design.
