  2. Allegro X APD
  3. slide hug only is wrong?
  • Subscribers 66
  • Views 5627
zpofrp
zpofrp over 1 year ago
Can you tell me which setting is causing this?
In the general edit. I try slide via to other position. but the slide is wrong.
in the cm,i set pad-pad connect is all allowed,and i turn off via to pad spacing in the same net spacing. only turn on via to via spacing in the same net spacing,set to via to via spacing =0.
default the via is closer to the pad edge, I think the correct location is show in the pic2.
  • SaiPavanl
    0 SaiPavanl over 1 year ago
    When you change the Bubble to OFF in the slide options, are you able to slide the via over the Pad?
  • zpofrp
    0 zpofrp over 1 year ago in reply to SaiPavanl
    Yes, but  if i change the bubble off, i dont know violation of rules when  slide the via. So i need to change bubble to hug only or hug preferred.
