  2. RF Design
  3. Crystal Oscillators
  • Subscribers 63
  • Views 5081
Crystal Oscillators
Youssef khaled
Youssef khaled over 1 year ago
Hello, Currently i am designing a 96MHZ crystal oscillator using pierce topology and also I use for amplitude gain control circuit for regulation. The problem is when i run a PSS + Pnoise i get these warnings :
WARNING (CMI-2375): M2: Vgs has exceeded the oxide breakdown voltage of `vbox' = 6 V.
WARNING (CMI-2375): M4: Vgs has exceeded the oxide breakdown voltage of `vbox' = 6 V.
WARNING (CMI-2377): M4: Vgd has exceeded the oxide breakdown voltage of `vbox' = 6 V.
WARNING (CMI-2377): M3: Vgd has exceeded the oxide breakdown voltage of `vbox' = 6.6 V.
and also WARNING (CMI-2682): M5: The bulk-drain junction forward bias voltage (1.38154 V) exceeds VjdmFwd'=851.514mV ,The results are now incorrect because the junction current model has been linearized
Note : i am using Supply 1.2 V hence it is not possible to exceed the oxide breakdown.
So i am asking why i am getting these warnings , it could be a convergence problem and the Results computed are not corrected.
Also when running DC and transient , i don't get these warnings.
