  2. RF Design
  3. Error in cds_srr (line 20)
  • Subscribers 63
  • Views 5211
sepideh
sepideh over 1 year ago
In the MATLAB, I am using cds_srr and cds_innersrr commands. Although I set the path to the spectre root, I face this error:
One or more output arguments not assigned during call to "cds_innersrr".
sig = cds_innersrr(dirname, dataset, signame, verbose);
Error in techsweep_spectre_run (line 64)
struct_n = cds_srr(c.outfile, c.sweep, params_n{1});
I would highly appreciate it if you could help me.
    I'm not sure how you expect anyone to point out the error - you've not shown your code - well, other than some fairly useless screenshots showing some variable assignments. You've not included the actual code which calls cds_srr, which would have been the most useful.
    Ideally, share the entire code as attachments to a post (screenshots are next to useless for code problems).
