  2. Allegro X APD
  3. Creating Power and Ground rings in Allegro X Package Designer...
  • Subscribers 66
  • Views 5213
Creating Power and Ground rings in Allegro X Package Designer Plus
mahimag
mahimag over 1 year ago
Power and Ground rings are exposed rings of metal surrounding a die that supply power/ground to the die and create a low-impedance path for the current flow. These rings ensure stable power distribution and reduce noise. Allegro X Package Designer Plus has a utility called Power/Ground Ring Generator which lets you define and place one or more shapes in the form of a ring around a die.
 To run the PWR/GND Generator Wizard, go to Route > Power/Ground Ring Generator or type "pring wizard" in the APD command window to invoke the Wizard.
This Wizard lets you define and place one or more shapes in the form of a ring around a die. The Power/Ground Ring Wizard creates up to 12 rings (shapes) at a time. If you require more rings, you can run the Power/Ground Ring Wizard as many times as needed. This command displays a wizard in which you can specify:
  • The number of rings to be generated
  • The creation of the first ring as a die flag (Die flag is the boundary of the die like the power ring.)
    • If you create a die flag and the first ring is the same net as the flag, you can enter a negative distance to overlap the ring and the die flag.
  • Multiple options for placement of the rings with respect to:
    • Origination point
    • Distance from the edge of the die
    • Distance from the nearest die pin on each die side
  • The reference designator of the die with which the rings will be used
  • The distance between rings
  • The width of each ring
  • The corner types on each ring (arc, chamfer, and right-angle)
  • An assigned net name for each ring
  • A label for each ring
The rings are basic in nature. For other shape geometries or split rings, choose Shape > Polygon or Shape > Compose/Decompose Shape from the menu in the design window.
Depending on the options selected, the Power/Ground Ring Wizard UI changes, representing how the rings will be created. Verify the Wizard settings to ensure that the rings are created as intended.
  1. When the Power/Ground Ring Wizard appears, set the number of rings to 2, accept the other defaults, and click Next. You can set Create first ring as die flag to create a basic die flag.
         2. Define Ring 1 and the net associated with it.
              a) Browse and choose Vss in the Net Names dialog box.
            b) Click OK.
            c) Specify the label as VSS.
            d) Click Next.
             The first ring should appear in your design. It is associated with the proper net; in this case, VSS.
  1. For the second ring, choose the net as Vdd and specify the label as VDD.
  2. Click Next.
  3. Click Finish in the Result Verification screen to complete the process.
The completed rings appear as shown below.
Now, when you click on Power and Ground Die Pin and add wirebonds, you will see that the wirebonds are placed directly on the Power and Ground rings.
