  2. RF Design
  3. Measuring DDJ (data dependent jitter). Cross function on...
  • Subscribers 63
  • Views 5468
Measuring DDJ (data dependent jitter). Cross function on eye-diagram
FPMKh
FPMKh over 1 year ago
My Virtuoso and Spectre Version: ICADVM20.1-64b.NYISR30.2
I plot an eye diagram using a built in function. I want to see the data-dependent jitter. I want to measure the eye diagram edges at zero crossing (width of that diamond part) shown in the pic by vertical and horizontal markers. I can put a marker and read the numbers there and get what I want. But now I want to run Monte Carlo and I can't do this for all samples. I wish I could write an expression for this. Unfortunately, I see that the function "cross" is not working on the eye diagram. Basically, when I send the eye diagram data to a table, I see that it actually is just the prbs data and not the eye diagram data. Is there a hack that can help me achieve my goal which is: having an expression to measure the edges of the eye diagram at zero crossing?
There is a script that Andrew wrote (https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin%3AViewSolution%3BsolutionNumber%3D11395772). This is a good script but it puts all edges on top of each other. I want to distinguish the two edges. In the attached pic (two-period eye diagram) you can see what I mean by the two edges (diamond shapes). I want to measure each of the two and take the maximum. Having all the edges on top of each other won't give me what I want. All edges together will lso include DCD. I purely want to measure DDJ. DCD is measured separately. I have very little experience with writing scripts and could not modify Andrew's script.
Your help is much appreciated. Thank you.
