  2. Allegro X APD
  3. Package Design Integrity Checks
  • Subscribers 69
  • Views 5401
TCHA
TCHA over 1 year ago
When things go wrong with your package design flow, it can sometimes be difficult to understand the cause of the issue. This can be something like a die component is wrongly identified as a BGA, a via stack has an alignment issue, or there are duplicate bondwires. These are just a few examples of issues; there can be many more. When interactive messages and log files do not help determine the problem, the Package Design Integrity Check tool becomes very handy. This feature lets you run integrity checks, which ensures that the database is configured correctly.
To invoke the command from Allegro X Advanced Package Designer, use the Tools > Package Design Integrity menu.
Or type package integrity at the Command  prompt.
The Package Design Integrity Checks dialog box includes all categories and checks currently registered for the currently running product. You can enable all these categories and checks or only the one that you want to run. This utility can fix errors automatically (where possible). Errors and warnings are written to the “package_design_check.log” file.
The utility can also be extended with your own custom rules based on your specific flows and needs.
  • RV20250702875
    RV20250702875 7 months ago
    I recently ran into an issue where a die was showing up as a BGA and it took forever to trace the problem manually. Definitely going to try this out next time.
  • LQ202507138522
    LQ202507138522 6 months ago in reply to RV20250702875
    Thanks for this, TCHA — super helpful! I ran into a weird issue last week where a via stack was flagged incorrectly and the log files didn’t point to anything useful. Tried this integrity check tool after seeing your post and it actually highlighted a mismatch I missed completely. Definitely adding this to my standard debug process from now on.
