  3. IC 23.1 installation configuration failure on RHEL 9
  • Subscribers 148
  • Views 4484
RaviUoS24
RaviUoS24 over 1 year ago
I am trying to install IC231 on RHEL 8 using installscape, however configuring keeps failing.
I tried to run the configuration file manually as suggested in one of the previous posts and it gives me following errors:
sh batch_configure.sh
/home/rs/cadence/installs/IC231/install/tmp/slconfig.sh: line 165: xterm: command not found
cat: ncvhdl23.03-d103lnx86_101124125631.stat: No such file or directory
rm: cannot remove 'ncvhdl23.03-d103lnx86_101124125631.stat': No such file or directory
cat: ncvhdl64b23.03-d103lnx86_101124125631.stat: No such file or directory
rm: cannot remove 'ncvhdl64b23.03-d103lnx86_101124125631.stat': No such file or directory
cat: oaRedist22.61-p003lnx86_101124125631.stat: No such file or directory
rm: cannot remove 'oaRedist22.61-p003lnx86_101124125631.stat': No such file or directory
cat: amsEnv64b23.10-p043lnx86_101124125631.stat: No such file or directory
rm: cannot remove 'amsEnv64b23.10-p043lnx86_101124125631.stat': No such file or directory
cat: ihdl64b23.10-p043lnx86_101124125631.stat: No such file or directory
rm: cannot remove 'ihdl64b23.10-p043lnx86_101124125631.stat': No such file or directory
I am not very well versed with Linux at the moment but trying. Could any one suggest something or point to what is missing?
  • ebecheto
    ebecheto over 1 year ago
    May be you do not have xterm installed on your computer.
    Install it with command :
    sudo dnf install epel-release #<= rhel8 does not come with xterm in the default repositories
    sudo dnf install xterm #<= proper install
    xterm -version #<= verify
