  3. How to have sub trees for sub trees
  • Subscribers 148
  • Views 3939
Purbayan
Purbayan over 1 year ago
I want to create sub tree of sub trees how can i do that?
I want to create another tree for the Sub parameter also.
; create a root tree
indexTree=hiCreateTree('index11)
hiTreeAppendItem(indexTree hiCreateTreeItem('dow11 list("Parameter 1")))
; create two sub-trees
dowTree11=hiCreateTree('dows11)
hiItemInsertTree(dow11 dowTree11)
nasTree11=hiCreateTree('nass11)
hiItemInsertTree(nas11 nasTree11)
hiTreeAppendItem(dowTree11 hiCreateTreeItem('ibm list("Sub Parameter 2" )))
ibm11=hiCreateTree('ibsm)
hiItemInsertTree(dowTree11 ibm11)
hiTreeAppendItem(ibm11 hiCreateTreeItem('cdn111 list("Sub Parameter 1" "tb1_par1" "tb2_par1")))
    Based on your variable names, you are presumably starting from this code: Example of a SKILL form with sortable hierarchical Tree table. How to install a form containing tree items in a window since bindkey work with windows but not with forms
    I can't copy the entire code here, but If you find this line in the code:
    sunw=hiCreateTreeItem('sunw list("Sun Micro" 27.750 4 "Sell"))
    and then add these lines below it:
    ;;; Create a sub-tree below Sun Micro
    sunSubTree=hiCreateTree('sunsubtree)
    hiTreeAppendItem(sunSubTree hiCreateTreeItem('java list("Java" 123 4 "Invented")))
    hiItemInsertTree(sunw sunSubTree)
    it will show you how to do this.
