  3. load via options into cadence session
  • Subscribers 148
  • Views 5450
psill00
psill00 over 1 year ago
What is the variable to define via selection/type for vias
I want to be able to load via cut type in the via option when I use the leHiCreateVia() function
I want to select/load to the Via Option menu on which via I want to use
Cadence version IC23.1.64b.ISR7.27
Paul
  • RobMan
    RobMan over 1 year ago
    Hi Paul,
    Please refer to this Article...
    How can I set default choice on Create Via form
    Rob,
  • psill00
    psill00 over 1 year ago in reply to RobMan
    I tried what the article has and it does put the via as defined, but I want the auto feature when I used the leHiCreateVia
    Not sure how to explain ( I dont want to upset the IP watchers )
    le0ViaForm->viaMode->value="Auto"
    _viaOpenCreateViaOptionFormCB()
    I dont want to use a via/contact
    viaOptionsForm->viaRestrictLayer22->value= nil
    I want to use a specific via/contact from the via list ( Example of a valid contact list '("contact" contactV" contactH") )
    viaOptionsForm->viaOptionDefCutClassCyclic21->value="contact"
    Is there a way I can set the contact/via values when I start cadence?
    Paul
  • psill00
    I tried the script in the article and it works as described, but I want the use the Auto feature in leHiCreateVia
    Not sure how to explain clear ( I dont want to upset the IP watchers )
    leHiCreateVia()
    I dont want to use a contact/via from the list
    I want to use a specific contact/via from the list ( Example of symbolic list '("contact" contactV" "contactH") )
    Is there a way I can set this type of values in a file or variable when I start up cadence?
    Paul
  • psill00
    leHiCreateVia()
    Paul
  • RobMan
    RobMan over 1 year ago in reply to psill00
    I don't follow: "Auto" will select the correct via for the overlapping layers. You cannot define the via in this mode.
    If there are variants you wish to restrict then you probably need to look at the Constraint Group or Via Configuration options.
  • psill00
    Sorry for the multiple replies, I clicked the send button and it showed it failed
    I think I found the answer
    How to set the default via, cutClasses, rows, columns in the Create->Via form. Programmatically update GUI fields and "click" OK on the form.
