  3. adexl remove test
  • Subscribers 148
  • Views 3790
adexl remove test
dogman4
dogman4 over 1 year ago
Hi,all
  I want to remove some Tests form adexl automatically,there have any function to achieve that?
    What do you mean by "automatically"? There are SKILL functions to delete tests with maestro views (maeDeleteTest) - if you are using the older ADE XL view (no longer supported), then you could use:
    sess=axlGetWindowSession()
    sdb=axlGetMainSetupDB(sess)
    test=axlGetTest(sdb "MyTest")
    axlRemoveElement(test)
    You can find out the test names using cadr(axlGetTests(sdb))
  • dogman4
    dogman4 over 1 year ago in reply to Andrew Beckett
    very thanks,Andrew,it works
