  3. How to create draw region button like the one used in the...
  • Subscribers 148
  • Views 4357
How to create draw region button like the one used in the Area and Density calculator
Betoo
Betoo over 1 year ago
I would like to create a button for my form that prompts the user to click on a cellview and draw a rectangle bounding box, exactly like the one used in the Area and Density Calculator. Can someone please help me with this?
Thanks!
Beto
  • Betoo
    Forgot to include a snip of the button. Here it is.
  • p94todorov
    p94todorov over 1 year ago in reply to Betoo
    Hi Beto,
    one way to do is through the callback of the button you create. You will need to bring up the desired cellView to focus and then call an enter function. In your case enterBox should do the trick. You can play around with the various parameters of the enter functions to control the outputs. The simple way will be to assign the return value of the enter function to a variable and do whatever you need within the callback.
    Petar
  • Betoo
    Betoo over 1 year ago in reply to p94todorov
    Thank Petar,
    enterBox along with Hilights accomplished this task
    Beto
