  3. Error ASSEMBLER-1600 when running script with two different...
  • Views 4700
Error ASSEMBLER-1600 when running script with two different MC simulations
Max Ludwig
Max Ludwig over 1 year ago
Hello Community,
I have encountered an issue that is a mystery to me and hope somebody could give me a clue about what is happening in Cadence and maybe even a solution?
I am running a test scripted in a SKILL file that sequentially opens two different projects with MC analyses and in between I get an error message box and also multiple logs in CIW with exactly the same text.
Both projects run a simulation with a call like this:
historyName = maeRunSimulation(?session sessionName ?waitUntilDone t)
After this the script closes the current project, opens the next project and executes the same line with maeRunSimulation() for the second project. Then immediately this error message happens, and also is logged repeatedly in the CIW window
The message box looks like this:
The logs I get in CIW:
nil
hiCancelProgressBox(_axlNetlistCreateProgressBar)
nil
hiCancelProgressBox(_axlUILoadForm)
nil
when(dwindow('axlDataViewessWindow1) hiMapWindow(dwindow('axlDataViewessWindow1)))
t
when(dwindow('axlRunSummaryessWindow1) hiMapWindow(dwindow('axlRunSummaryessWindow1)))
t
ERROR (ASSEMBLER-1600): Cannot find an active session named fnxSession0.
You can only modify an ADE Assembler session that is active.
Perhaps the session name was misspelled or has not yet been created.
Verify the session name matches an existing ADE Assembler session.
1>
*WARNING* hiDisplayAppDBox: modal dbox 'adexlMessageDialog' is already displayed!
  • FA202502211212
    FA202502211212 10 months ago
    Could you fix this and how? I am running into similar issues today
    Andrew Beckett 10 months ago in reply to FA202502211212
    Without seeing the script, knowing which version you are using, it's rather hard. Most likely in the original case the sessionName was not being updated between the runs, and an maeCloseSession() had closed it.
