  3. Prevent routing on adjacent layers without affecting po...
  • State Verified Answer
  • Subscribers 160
  • Views 4001
Prevent routing on adjacent layers without affecting pour
FilipSwe
FilipSwe over 1 year ago
I have a sensitive trace on layer 2 and I would like to prevent any routing along or across it on adjacent layers (L1 and L3).
My idea was to use a route keepout shape on L1 and L3, however that also removed the ground pour on those layers and I would like to keep the ground pour.
Can I get around this somehow or should I use something else than route keepout?
Filip
  • DavidJHutchins
    +1 DavidJHutchins over 1 year ago
    Try adding the 'Shapes_Allowed' property to the keepout shape
  • FilipSwe
    0 FilipSwe over 1 year ago in reply to DavidJHutchins
    Works, thank you sir!
