  3. spreading clines
  • State Verified Answer
  • Subscribers 162
  • Views 5003
spreading clines
masamasa
masamasa over 1 year ago
hello.
i have asked this question a few years back but no good answer so i ask again.
i would like to spread clines with equal spacing.
i do know how to spread clines between vias.
but i would like to simply spread clines between two clines (not between two vias).
for instance, there are 4 parallel clines but the inner 3 spaces are not equal so i would like to move the inner 2 clines to make the 3 spaces equal.
regards
masa
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago
    I think the closest functionality to what you are looking for is the 'spread between voids' command, available from the 'Route>Resize/Respace>Spread Between Voids'
  • masamasa
    0 masamasa over 1 year ago in reply to DavidJHutchins
    thank u for ur response, david.
    unfortunately the function of spreading clines between two vias does not work if there is no via around the clines.
    is it possible to create a skill code for this?
    regards
    masa
  • Hoangkhoipcb
    +1 Hoangkhoipcb over 1 year ago in reply to masamasa
    Hi masa!
    You can try this code:
    axlCmdRegister("spread_clines" `spread_clines )
    (defun spread_clines ()
    if(axlOKToProceed() == nil then
    axlShellPost("done")
    axlShell("setwindow pcb; prepopup 0.0 0.0; done")
    axlCmdRegister("_spread_clines" `_spread_clines ?cmdType "general")
    axlShellPost("_spread_clines")
    (defun _spread_clines ()
    mypopup = axlUIPopupDefine(nil (list (list "Done" 'axlFinishEnterFun) (list "Cancel" 'axlCancelEnterFun) ))
    axlUIPopupSet(mypopup)
    gridSnap1 = axlEnterPoint(?prompts list("Pick origin point") )
    if(gridSnap1 != nil then
    gridSnap2 = axlEnterPoint(?prompts list("Pick origin point") )
    else
    gridSnap2 = nil
    if(gridSnap1 != nil && gridSnap2 != nil then
    ;axlDBCreateLine(list(gridSnap1 gridSnap2) 5.0, "ANTI ETCH/ALL" )
    axlSetFindFilter(?enabled '(noall CLINESEGS NAMEFORM) ?onButtons '(noall ALL))
    axlSingleSelectPoint(gridSnap1)
    seg1 = car(setof(e axlGetSelSet() e->xy == nil))
    axlClearSelSet()
    if(seg1 != nil then
    ol1 = axl_ol_ol2(list(gridSnap1 axlMXYAdd(0.0 : 0.01 gridSnap1)) seg1->startEnd)
    gridSnap1 = cadr(ol1)
    axlSingleSelectPoint(gridSnap2)
    seg2 = car(setof(e axlGetSelSet() e->xy == nil))
    axlClearSelSet()
    if(seg2 != nil then
    ol2 = axl_ol_ol2(list(gridSnap2 axlMXYAdd(0.0 : 0.01 gridSnap2)) seg2->startEnd)
    gridSnap2 = cadr(ol2)
    r_path = axlMakeDynamicsPath(list(list(gridSnap1 gridSnap2 0.001) list(gridSnap2 gridSnap1 0.001) ))
    poly = car(axlPolyFromDB(r_path ?layer "ANTI ETCH/ALL" ?endCapType 'NONE ?line2poly t ))
    if(poly != nil then
    axlAddSelectPoly(poly t)
    sel_list = setof(e axlGetSelSet() e->xy == nil)
    axlClearSelSet()
    if(length(sel_list~>parent) != length(unique(sel_list~>parent)) then
    printf("Existting segs parent duplicate")
    else
    number_div = axlDistance( gridSnap1 gridSnap2 )/(length(sel_list) - 1)
    tmp_point = gridSnap1
    point_list = nil
    loop = t
    while(loop == t
    if(axlDistance(gridSnap1 tmp_point) > axlDistance(gridSnap1 gridSnap2) then
    loop = nil
    else
    point_list = cons(tmp_point point_list)
    inter_points = axlGeoCircleLineInt2(gridSnap1 gridSnap2 tmp_point number_div)
    dis1 = axlDistance( car(inter_points) gridSnap2 )
    dis2 = axlDistance( cadr(inter_points) gridSnap2 )
    if(dis1 < dis2 then
    tmp_point = car(inter_points)
    else
    tmp_point = cadr(inter_points)
    point_list = cons(gridSnap2 point_list)
    point_list = reverse(unique(point_list))
    ol_seg_list = nil
    i = 0
    foreach(seg sel_list
    ol_ol = axl_ol_ol2(seg->startEnd list(gridSnap1 gridSnap2))
    if(caddr(ol_ol) <= 0.0 then
    ol_seg_list = cons(car(ol_ol) ol_seg_list)
    tmp = nil
    foreach(item ol_seg_list
    tmp = cons(list(axlDistance(gridSnap1 item) item) tmp)
    tmp = sortcar(tmp 'lessp)
    i = 0
    cmd_str_list = nil
    foreach(item tmp
    point = cadr(item)
    point2 = nth(i point_list)
    i++
    cmd_str_list = cons( sprintf(nil "pick %f %f; pick %f %f" xCoord(point) yCoord(point) xCoord(point2) yCoord(point2)) cmd_str_list)
    if(cmd_str_list != nil then
    axlShell("setwindow pcb; slide; setwindow form.find; FORM find cline_segs YES ; FORM mini allow_errors YES;")
    foreach(cmd cmd_str_list
    axlShell(cmd)
    axlShell("setwindow pcb; done")
    axlShell("setwindow pcb; prepopup 0.0 0.0; setwindow pcb; done;")
    axlCmdUnregister("_spread_clines")
    printf("Last Update: 01/11/2024 -Version 1.0\n")
    HoangKhoi.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to Hoangkhoipcb
    cmd: spread_clines
    Usage: enter point1->enter point2->done
    All the Clines between point1 and point2 are spreading
  • masamasa
    0 masamasa over 1 year ago in reply to Hoangkhoipcb
    thank u, hoangkhoi.
    amazing!
    it works.
    thank u.
    regards
    masa
