  3. SKILL regex pattern matching
  • Views 5071
anushar
anushar over 1 year ago
I have a string "[@global_vddi:%:vddi!]" which I need to process to remove "@[]" chars. The desired result is "global_vddi:%:vddi!". I tried the following in CIW
netExpr = "[@global_vddi:%:vddi!]"
rexCompile("\\([a-zA-Z0-9_:!%]+\\)")
t
rexExecute(netExpr)
t
rexSubstitute( "\\0" )
and I achieved the desired value. I added the same code to my script but it didn't work. In my script rexExecute returns 't' but rexSubstitute returns 'nil'
Here is the snippet from my script
netExpr = dbGetTermNetExpr(term)
if(netExpr then
rexExecute(netExpr)
netExpr1 = rexSubstitute( "\\0" )
. ..)  and trace log showing the variable values as the code executes
stopped before evaluating dbGetTermNetExpr(term)
after evaluating dbGetTermNetExpr(term)==> "[@global_vddi:%:vddi!]"
after evaluating (netExpr = dbGetTermNetExpr(term))==> "[@global_vddi:%:vddi!]"
stopped before evaluating if(netExpr then rexCompile("\\([a-zA-Z0-9_:!%]+\\)") rexExecute(netExpr) (netExpr1 = rexSubstitute("\\0")) ... )
stopped before evaluating rexCompile("\\([a-zA-Z0-9_:!%]+\\)")
after evaluating rexCompile("\\([a-zA-Z0-9_:!%]+\\)")==> t
stopped before evaluating rexExecute(netExpr)
after evaluating rexExecute(netExpr)==> t
stopped before evaluating (netExpr1 = rexSubstitute("\\0"))
stopped before evaluating rexSubstitute("\\0")
after evaluating rexSubstitute("\\0")==> nil
|[2]netExpr1 set to nil, was nil
Any help or suggestions as to why the code executes differently in CIW and when called from a SKILL script file will be much appreciated.
I also tried a different approach using rexReplace instead of rexSubstitute but couldn't get the regex pattern correct. The code I tried in CIW using rexReplace is as follows
a = "[@global_vddi:%:vddi!]"
rexCompile("\\([@\\[\\]]*\\)")
t
rexReplace(a "" 0)
"global_vddi:%:vddi!]"
Only '@[' get replaced and ']' is still present. The regex pattern contains '\\]' to match the closing square bracket yet it is not replaced. Please let me know what I'm missing in these 2 scenarios.
Any help is much appreciated!!
Confused SKILL user
  • henker
    henker over 1 year ago
    I wouldn't bother with a regex here if not really necessary (woukd be "^\\[@([^]]+)\\]$"),
    e.g. dbParseSigNetExpr is prob. easier to use, and there are also other options, but cannot post them; the forum gives me error, when I add them.
    str = "[@ABC:%:abc!]"
    ; regex
    reg = pcreCompile("^\\[@([^]]+)\\]$")
    ; advantage of regex is that it can test the format
    when(pcreExecute(reg str)
    ; the first capture is in \\1
    printf("regex : %s\n" pcreSubstitute(reg "\\1"))
    ; also tests the format
    arr = dbParseSigNetExpr( str ) ; splits into '(@ ABC % abc!)
    ; compine to your liking
    printf("sigparse+print: %s:%%:%s\n" cadr(arr) cadddr(arr))
    printf("sigparse+build: %s\n" buildString(cdr(arr) ":"))
    ; split on unwanted chars
    printf("strparse : %s\n" car(parseString( str "[@]")))
    ; or just remove the envelop with substring
