  3. AllegroX SPACING rule precedence
  • State Suggested Answer
  • Answers 1
  • Subscribers 162
  • Views 3966
grax
grax over 1 year ago
Hi
the signal SPI_SCLK belongs to TWO Spacing CLASSES: CLS_SP_SPI and CLS_SP_SPI_CLOCK
I then assign TWO different SPACING RULES to each class : CLS_SP_SPI  > 2H and CLS_SP_SPI_CLOCK > 3.5H
Which SPACING RULE will inherit the signal SPI_SCLK ??
Is it possible to manually define the PRIORITY on Design Rules ??
  • techiecs
    0 techiecs over 1 year ago
    Generally in the case of conflict, the more conservative value is applied when two objects are constrained at the same hierarchical level. Otherwise it follows the precedence order of the hierarchical constraints.
    Say if you have regions defined in your board file, then Region rules override any other Spacing Constraints.
