  3. Shape won't connect to pad
  • Subscribers 159
  • Views 980
Fredda
Fredda over 1 year ago
I have a small shape for connecting three SMD pads, but it won't connect to one of the pads (0.2x0.6 mm). Thermal relief connects are set to Full contact for SMD pin in Shape parameters, but that doesn't help.
However, if I decrease the Minimum aperture for gap width in Void controls in Shape parameters to something below 0.2 mm the shape connects to the pad. But it is a little contracted at the pad entrance. Just 0.002 mm. What is going on here?
Tried to attach some pictures, but I get: "An error occurred. Please try again or contact your administrator.". Will try later again.
/F
  • Gowtham P
    0 Gowtham P over 1 year ago
    Hi  Fredda
    We need more data to help you with this requirement. I will be contacting you through another channel for this.
