  3. Loading Footprints keep getting DB Doctor message
  • Views 5419
Sagetech
Sagetech over 1 year ago
Loading new netlist into 23.1 Apparently it does not like many of the specified footprints or padstacks. I have to open the footprint in 231., save the pad stack then save the footprint. This is very time consuming and frustrating to say the least.
I also get the following message
WARNING(SPMHNI-194): Symbol 'SMD_SOD123_ANODE_PIN1' used by RefDes D30 for device 'DIODE_0_SMD_SOD123_ANODE_PIN1_1N4148W-7-F' not found.
The symbol either does not exist in the library path (PSMPATH) or is an old symbol from a previous release.
Set the correct library path if not set or use dbdo
     The current version of software is unable to open design smd_sod123_anode_pin1.
The design was last saved using version 16.5 and must be updated using DB Doctor. [help]
Going to DB Doctor does nothing, no option to update a footprint?
Tom
  • Sagetech
    0 Sagetech over 1 year ago
    More info. This part is in the path directory and has had both the part itself and the pads saved in 23.1
    Symbol 'SM_S0T363' used by RefDes D49 for device 'SD103ATW_SM_S0T363_SD103ATW' not found.
    Set the correct library path if not set or use dbdoctor to migrate old symbol
  • Sagetech
    When I get the above messages, my only option so far is to open the footprint in 17.4, run DB Doctor on it. Save each padstack, save the part and exit from 17.4. Open 23.1, load the part, run DB Doctor on it, close the part, load the board file and import the netlist. The part will now load but I have probably 100 parts that won't and need this procedure done to get them to load.
    There must be a better way...........??
  • Ulf K
    0 Ulf K over 1 year ago in reply to Sagetech
    I experienced the same situation some time ago. The problem and its solution was discussed here.
    There is a "separate" executable GUI version of DBDoctor in the \tools\bin (Check that - Not at my CAD computer right now) that can do batch updating of footprints.
    What it does is to load each symbol, perform the update and then save them in as newer version.
    This version supports wild cards. No need to load each footprint.
  • AsbjornEdvalds
    0 AsbjornEdvalds over 1 year ago in reply to Sagetech
    With your installation there should be a dbdoctor_ui.exe. You can get that to run on all files in a folder by specifying a wildcard in the input design name
    E.g. C:\folder\lib\*.*
    This will update all the design files in the folder specified to the version of the dbdoctor
