  3. exporting a modified symbol out
  • Replies 7
  • Subscribers 160
  • Views 5076
masamasa
masamasa over 1 year ago
hello:
i place a symbol into my design.
on my design, i change the symbol property by unlocking the symbol and unfixing pins so that i can move pins on the symbol.
i move some pins on my design.
but when i export the symbol from my design, the symbol is not current but has the original pin location.
is there a way to retain the pin locations after moving pins on a symbol when exporting the symbol?
regards
masa
  • SaiPavanl
    0 SaiPavanl over 1 year ago
    Hello Masa,  Allegro keeps a copy of the symbol definition with the database. A modified symbol(moving pin or Text location etc) is a symbol instance and when dumping the
    libraries Allegro dumps the symbol definitions only.
    Therefore .a modified symbol is a symbol instance and when dumping the libraries Allegro dumps the symbol definitions.
    Modified padstack definitions can be exported, but not pin location changes.
  • masamasa
    0 masamasa over 1 year ago in reply to SaiPavanl
    thank u for ur reply.
    can i export the original padstack definition after i modify the padstack on my desgin?
    regards
    masa
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to masamasa
    Hi Masa,
    I believe that when you modify a padstack in Allegro or APD and then use File > Export > Libraries
    you are exporting the modified padstack data
  • masamasa
    0 masamasa over 1 year ago in reply to DavidJHutchins
    thank u for response.
    well, i wonder why i can export the modified padstack but not the original padstack which is a padstack before the modification.
    in the same token, how come i can export the original symbol but not the modified symbol?
    how are the padstack and symbol treated differently while they r exported out?
    regards
    masa
  • DavidJHutchins
    Hi Masa,
    When you load a symbol into allegro/APD it loads the data into a SYMDEF object type, the placed symbols are copies of that data
    When you modify a symbol in a design layout you are changing the copied data, not the original data loaded from a symbol file
