  3. how can load the Dll files and use it in Allegro 16.6
  • Subscribers 161
  • Views 4275
Hoangkhoipcb
Hoangkhoipcb over 1 year ago
Hello everyone!
Have you ever used the axlDllOpen function for Allegro 16.6?
It doesn't work for me. Please give me your solution.
Thank you.
HoangKhoi
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    I found the solution to this problem. And .dll file is successfully loaded.
  • AsbjornEdvalds
    0 AsbjornEdvalds over 1 year ago in reply to Hoangkhoipcb
    Hi HoangKhoi,
    Please post your solution here so other people facing the same issue can benefit from your learnings.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to AsbjornEdvalds
    Hi AsbjornEdvalds!
    PCB Allegro version 16.6 supports only 32-bit DLLs. I previously built a 64-bit DLL, which worked with versions 17.2 and 17.4. Therefore, you should split them into 32-bit and 64-bit versions. Version 16.6 requires a 32-bit DLL.
    Thank You & Best Regards,
    HoangKhoi.
