  3. How to restrict the variable's data type of procedure with...
  • Subscribers 148
  • Views 1253
How to restrict the variable's data type of procedure with @key
JamesJames
JamesJames over 1 year ago
I want to define a procedure that with @key, and I also want to restrict the variable's datatype, I tried with folloing but I received error in CIW
procedure(tt(handler @key str1 str2 "ssS")
  printf("handler: %L\n" handler)
tt('test)
The error is like: *Error* tt: argument for keyword ?str1 should be a symbol (type template = "ssS") at line 11 of file
James
    James,
    Since you are not passing either of the keyword arguments, their default value is nil, which doesn’t match the type template. You’d have to ensure that the default value is a string or a symbol - e.g. @key (str1 ‘none) or something like that. Or give the type template as “g” and add an explicit check for the value either being nil or symbolp(str1) within the code.
  • JamesJames
    JamesJames over 1 year ago in reply to Andrew Beckett
    Thanks Andrew, I get it.
    James
