  3. Smd pin to smd pin spacing
  • Subscribers 162
  • Views 4364
FilipSwe
FilipSwe over 1 year ago
Trying to figure out why this situation does not generate a DRC error.
A resistor was accidently placed so the pad was on top of another pad. See picture:
I have checked the CM and both Spacing Constraint Set and Same Net Spacing Constraint Set have Smd pin to Smd pin set to 0.1 mm.
I'm using Allegro PCB designer 22.1.
If someone has an idea why this does not give a DRC i would appreciate it. Thanks.
Filip
  • avant
    0 avant over 1 year ago
    You could set the "pad-to-pad connect" to "not_allowed"  in the physical constraint set.
  • oldmouldy
    0 oldmouldy over 1 year ago
    Chances are that all Same Net Spacing checks are disabled. Open the Constraint Manager and use Analyze>Analysis Mode. Look in Same Net Spacing and enable SMD Pin to SMD Pin. Same Net checks are typically disabled because of the number of "false positives" flagged with "everything" enabled.
