  3. How to perform the reflection and crosstalk using the OrCAD...
  • State Suggested Answer
  • Answers 1
  • Subscribers 162
  • Views 3995
How to perform the reflection and crosstalk using the OrCAD X Professional
RohitRohan
RohitRohan over 1 year ago
Dear Community,
I have created a PCB layout with multiple high-speed nets, I want to check the SI like how signals are reflected and taken to each other.
I have the OrCAD X Professional, how to check the reflection and crosstalk using the OrCAD X Professional software version 24.1.
I want to create a topology flow to the PCB layout and perform the reflection and crosstalk.
Rohit Rohan
  • mahimag
    0 mahimag over 1 year ago
    Hello RohitRohan ,With OrCAD X Professional or Allegro PCB Designer base license, you will only be able to see 2 workflows "impedance" and "coupling".  If the Allegro PCB Designer license is selected with High-Speed Option (or any higher suite license), you should be able to see all the other workflows like crosstalk and reflection.
