  2. Allegro X APD
  3. How to transfer etch/conductor delays from Allegro Package...
  • Subscribers 65
  • Views 1755
How to transfer etch/conductor delays from Allegro Package Designer (APD) to pin delays in Allegro PCB Editor
JuanCR
JuanCR over 1 year ago
The packaging group has finished their design in Allegro Package Designer (APD) and I want to use the etch/conductor delay information from the mcm file in the board design in Allegro PCB Designer. Is there a method to do this?
This can be done by exporting the etch/conductor data from APD and importing it as PIN_DELAY information into Allegro PCB Editor.
If you are generating a length report for use in Allegro Pin Delay, you should consider changing the APD units to Mils and uncheck the Time Delay Report.
In Allegro Package Designer:
  1. Select File > Export > Board Level Component.
  2. Select HDL for the Output format and select OK.
       3. Choose a padstack for use when generating the component and select OK.
This will create a file, package_pin_delay.rpt, in the component subdirectory of the current working directory. This file will contain the etch/conductor delay information that can be imported into Allegro.
In Allegro PCB Editor:
  1. Make sure that the device you want to import delays to is placed in your board design and is visible.
  2. Select File > Import > Pin delay.
  3. Browse to the component directory and select package_pin_delay.rpt. The browser defaults to look for *.csv files so you will need to change the Files of type to *.* to select the file.
  4. You may be prompted with an error message stating that the component cannot be found and you should select one. If so, select the appropriate component.
  5. Select Import.
  6. Once the import is completed, select Close.
Note: It is important that all non-trace shapes have a VOLTAGE property so they will not be processed by the the 2D field solver. You should run Reports > Net Delay Report in APD prior to generating the board-level component. This will display the net name of each net as it is processed. If you miss a VOLTAGE property on a net, the net name will show in the report processing window, and you will know which net needs the property.
